Brucer
took a 700r4 tranny to have it gone through, basicly check the clutches and such, and to put a transgo shiftkit in it..
learned something while i was there. a holley carb throttle arm does not have the correct ratio for the 700r4 to function correctly.. the reason , 700r4's were never put behind a holley, therefore holley didnt have to correct it for a factory application, you can buy an extension that mounts on your existing throttle arm, or they make a complete replacement plate.. without the correct ratio, your trans doesnt build the correct pressure and will shift sluggishly..
