Gerry
Need some help please.
MIG is not my choice of welding method although I do use it now and then.
Question is: I have been advised that MIG is probably the best way to go for the welding on my fuel tank. Its made of 2mm thick MS and does benefit from most of the parts being formed with a fold in them. Reason I have been told to use MIG is that it puts less heat in and so should minimize distortion. So can you guys give me an idea of the amperage, wire thickness and speed that would be a good starting point. I really dont want to go the TIG route as I think it will take many hours to do all the weld. There is about 200 inches of weld on the tank alone.
Any help appreciated.
I was trained on Arc, TIG and gas but not MIG so my experience with it is limited. I find the weld always seems to build too much, giving a high bead. Not what i want on the seams of the tank.
Gerry
Gerry
