anti roll bar
Mine corners nice and flat and doesn't need one.
In my Opinion.......If you have a properly installed and adjusted Panhard Bar or Watts Linkage, you won't need the track bar.
Most T-Bucket frames are pretty tite and most won't have enough area to mount a lot of suspention "add-on's".. jus my 2 bits "BH"
like others are saying,no need,but if ya did use one on t-bucket at all,it would be in the rear not not front to cut roll. Yet if you have much roll,there is something wrong,most likely you have springs that are too soft or your shackels are not at about 45* as they should be. So check that before adding a roll bar[sway bar].
