MAX-FIRE DISTRIBUTOR-CHEVY C9000 CAP
Chevrolet V8 262-400, 396-502 with COMP 9000 Cap. This distributor combines all of the features of a modern digital capacitive discharge ignition with a state-of-the-art electronic advance distributor. Multi-Strike CD features include digital processing for maximum timing accuracy and the latest hi tech surface mount technology. Fires multiple sparks for 20+ degrees at low engine speeds for better throttle response, quicker acceleration and cleaner burning plugs. Has full electronic timing control - both RPM and vacuum based. There are 7 preprogrammed custom advance curves or design your own using free windows based software. The Vacuum Advance comes preprogrammed for high performance use or it can be custom curved using the design software included. The 3 BAR Map Sensor allows for fully adjustable boost proportional retard and can handle up to 30 pounds of boost. Single stage rev limiting, easy to adjust either inside the distributor or with the software - no chips required. The free windows-based software runs on any laptop or PC, whether the distributor is in the engine or not. All Wiring Harnesses are included and feature weather proof terminals for maximum dependability. All CNC machined billet construction to ensure maximum precision. Interchangeable Distributor Cap feature allows for 2 popular cap styles to be used to best suit the application and available clearance.
http://www.malloryracing.com/Produc...r=1248204&productID=2127&MajID=530&MinID=5302
![1248204.jpg](/proxy.php?image=http%3A%2F%2Fgo.mrgasket.com%2FProductImages%2F350%2F1248204.jpg&hash=75b2faa8501f8d14a93abe61334d6228)
