I really dislike the sound of the glasspacks in the short collectors on my bucket. They're not just loud, they're raspy and don't produce much low-end rumble. Has anyone tried the "auger" style mufflers from Speedway? I realize they're not going to be quiet, but I'm wondering if the tone is better.
Jack
OK, I'm checking back in on the case of a nice tone. The SuperTrapp, got a good sound, but the motor would not even rev decent....it was constipated, big time.
I tool the Auger style baffle, cut just ahead of the last auger, so it only has 2 augers on it. Wrapper some fiberglass matting around it, tie'ing it down with SS wire. slid it on up into the tube.
I then cut the end off a set of Thrush Track Mufflers, 4 1/2" long. 1st, I measured so there was 1 inch of the exit tube sticking out. I cut that off. I measure back 4 1/2" from that point, threw it in the chop saw, chopped it off.
So, the end of that muffler looks like a piece of perforated tubing with some fiberglass matting around it, the rounded end of the muffler (its a big glass-pack), then a little short piece of exit pipe.
The Drag Assoc. says these track mufflers were necessary, you can find a ton of these old things all over....ranging from 3 to 4 inch dia.'s.
I shoved the auger in so the tube where I cut off the last auger was sticking back toward the end of the lake header, I tacked a small bracket onto the end of the track muffler I cut off. I pushed the very end of the track muffler into the lake pipe, the 1" exit flush with the end of the lake pipe. I then put a screw hole into the pipe to hold the end of the muffler stationary.
I started it up, It had a pretty mellow low tone....one of the guys said it sounded like one on the early turbo mufflers. It was kinda loud and kinda low at the same time. But when you rev it, that tinty sound is replaced with a nice snarl. The guys like the sound, the tintyness is almost gone, and it revs good.
When I put the end of the glasspackup to the lakepipe, getting ready to slid it in, I pulled the tube of the auger, slid it into the perforated tube of the end of the glasspack, then I fastened it in. The auger did rattle around some since it was sitting in there loosely. Tried it a bunch of times, got a thumbs up.
Now, I'm making a taper to slide up into the lakepipe, will weld everything to it, then install the unit. I'm also tacking (2) 1/4-20 nuts into the inside of this thing with drilled holes so I can mount in securely. Then I can mount my turndown to the lakepipe flange and be done.
Hope this helps someone. While you should be able to reproduce this pretty closely, remember, I'm running a BigBlock, the sound of a smallblock might need more wrapping around the auger....
