Howdy
New to this. I posted one other time about the restrictive legislation here (South Australia) stops me from fabrication a frame for a T and I was intending to use a A model frame I have. I have since decided that the A is not a good choice and I'm going to use some think like a late '20's Dodge, and Essex or a Chevy - essentially some hing with straight rails. I want to build a Lakes/Track flavored car so a lot of my thinking is different to the conventional T bucket. One of the things I like so much about the T is the different ways you can built 'em but to get back on the topic... Given the base of the fire wall of a '23 is around 22" do you guys run your rails parallel back to front? Or do you taper them front to rear or 'am I way off here?
Cheers
Tony
Cheers
Tony
