Martin
Keepers thread on cutting thickmetal got me thinking whether or not I could cut something like a batwing on my mill. It occured to me that I could cut the radiuses with a rotary table, and connect the circles with straight lines. I thought I'd try it on a piece of wood just to go through the motions once. It turned out to be even easier than I thought it would be, and I cant see why it wouldnt work on a piece of plate steel. When I get a little more free time I'm going to try it.
I got the picture from a Total Performance plan, and started by drilling the holes.
I bolted the piece through the center of the rotary table, lined the cutter up and spun it around.
Next I spun the rotary table untill the straight lines lined up with either the X ro Y axis, and cut them.
Everything is cut except the axle hole, if I were doing this for real I would be making a pair and would bolt both pieces down back to back and cut both at one time.
If the piece were rough cut first the actual milling on one of these could be done in less than half an hour. If all the rotary table settings were recorded it would be even faster.
The only thing I am unsure of is how stable my little rotary table will be cutting steel, that could slow things down some, but I still think it will work. A bigger rotary table and a metal band saw are still on my christmas list, I have been watching Craigs list and have seen a couple nice older USA made band saws in the $100 range, just a little farther than I want to drive. Sooner or later something will come up.
