OldredT said:I have a blown big block chevrolet in my T and runs very respectful, this is what most people look like after a quick jump on the throttle. Do you need this much hp in a T ? No not really, but it is alot of fun. 1 thing to watch out for when you put a big block in is the fuel pump, if you set the engine in the frame lower the mechanical fuel pump will hit the frame, or at least it did on my car. Go for it, I started out with a 454 HO GM crate engine for a year or 2 and then added more stuff in it and a blower. Have fun and becareful if you run a big block in your T, They get kinda hairy.
409T said:Here's a few pictures of a W motor in a T bucket frame if anyone is interested
black30
Ted Brown said:Block to block, the BBC and a SSC will run together, the BBC wants to be let out to run, The faster it goes, the more pull it has,,, and no matter the weight, I also had one in a 60 Chevy, even with 4 people in the car, it ran the same. The frame engine mounts are the same for both engines, but better use a 400 trans, as the 350 will spit out second gear if you have any power at all. That is how it was and is with my T experiences... :faint:
