Humidi-T
I must be missing some pieces.
The crank hub I have has a v-groove on it, but if the hub is installed such that the shank is fully advanced in the seal, the belt groove is right up against the timing cover. This doesn't work if running a water pump. Also the lower pulley would be too close to the motor and wouldn't line up with the blower.
I suspect I am missing a spacer and another set of V-groove pulleys. Do any of you have pictures of their lower pulley set up. SBC with 4-71 blower.
Also, how did you address the water neck coming straight out in the drive belts. I need the upper hose to come out to the #3 cylinder then turn to the front. This is not insurmountable, just want to see how you dunnit.
Blower is all mounted and ready to run if I can get my pulleys and alt/pump straightened out.
