Brucer
Things been kind of quet around here
but not in my garage.
got the biggest part of the job done,old floor pans cut out, old cross braces cut out, and rewelded, new crossbraces made and welded in, channeled 1 1/2 inches, still need to make mounts and the flooring..
my low shell should look fine now.. i'm really to the point i need a profile look at the car, going to get the quickchange with axles in it first and then i will get a better look at it outside from a full side shot.. you guys will definetly get pictures with that, and i'm going to want your opinions for sure..
when you look at it, pay attention to the distributor location in relation to the hood hinge (the bracket at center on the firewall) whatever its called
the pictures arent in the same resolution, i messed with my camera and need to swap it back to the other resolution, they look better.
before
after
before
after
