I will be using a Wilwood aluminum floor mount pedal assembly that I want bolted to the top of the frame, instead of the floor. I would like to avoid having to have tubes welded in. Instead, I'd like to put holes in the bottom of the frame rail large enough for bolts, washers, and a socket to fit through...and end up just bolting through the top of the frame rail. After, a plate would be put over the holes in the bottom of the rail, fastened with self tapping screws. Does this sound like a safe and workable plan? Any alternatives?
On the other end, the rear lower control arm brackets need to be fastened to the bottom of the frame rails. Would the same method, with heavier hardware, work safely?
