T-Bucket Bob
Hey Guys,
Can you bondo over primer or should the primer be sanded?
Thanks, T-Bucket Bob
Ted Brown said:... Green stuff body filler is nothing more than thick primer, to be used over primer...
T-Bucket Bob said:Hey Guys,
Thanks, T-Bucket Bob :lol:
LumenAl said:Meangreen... question... I don't have the skills to nail the bondo in one take, are you suggestion that anywhere I need to float or skim coat an area that I take it down to the glass or metal every time?
Ted Brown said:...the trick for all fillers is to be completely DRY before any type of paint or even primer is put over it, as then it may never dry completely and it then will draw moisture, when it is completely DRY, it will not...
T-Bucket Bob said:So does that mean, if I want to smooth out corners and where brackets are, I will have to strip the primer off and then apply the bondo?
T-Bucket Bob![]()
