akitagandy
Is there a good diagram on brake system and what size lines and where to use what
The secret to the Stainless Tubing Flair is to deburr the cut end.I used a center drill so that the pilot point went into the tube to deburr the i.d. of the tube also.EX JUNK said:On my '37 I used the same thing, Al, but I said NEVER again. As you said, it is a real pain doing it that way. The making of the double flare is the real problem even with the "softer" stainless tubing and I would NEVER suggest using a single 45 degree flare on a brake system. That is why I used all stainless AN fittings with the stainless line on the T. Sure, it cost more to do it that way but it is the RIGHT way to do it if you want it to look great and work great forever and still be easy to do.
