BUILT IN CASTER
guilld
With a spring behind axle do you build in caster with the spring perch? I know with 32's it is built into the front cross memeber.
I mounted my spring perch horizontal and adjusted the caster with the four link.
The perch can be mounted straight on a spring behind. The pivots that bolt into the bat wings
allow caster to be adjusted on the axle. If you are using a spring over axle with no pivots then the perch is angled to get the caster.
The axles that we build, we put 5 degrees of caster in the bat wings so you don't have to do too much adjusting on the clevis.
