trogdor
I have most of my parts and pieces all ready, I just need to put them together. I have a Speedway frame and rear coil-over hairpin suspension kit. My question is, can I weld in the suspension before I install the engine or body? I'm worried that if I weld in the front/rear suspension mount points with no weight on the frame, when I mount the body/engine things like ride height will change. How do I know how much the rear shocks will compress? Or the front leaf spring? I'm worried that if I weld in everything with no weight it won't be level when everything else is installed. What is the usual order of assembly? Engine/body on frame first then suspension? Or suspension first?
