Here is a chassis bracket package kit, and trans mount and cross member. The cross member welds in and trans mount bolts to that. This allows you to have a welded in cross member and still be able to remove the trans with out pulling the radiator and engine. All the pieces separate would total $245.00 we are selling it for $195.00. 4 radius rod brackets, upper coil over shock mounts, lower rear shock mounts, panhard brackets, rear radius rod brackets, under chassis Vega steering mount, front perch with lower plate, and motor mount frame brackets.
![chassispackage.jpg](/proxy.php?image=http%3A%2F%2Fi131.photobucket.com%2Falbums%2Fp301%2FRPM_bucket%2Fchassispackage.jpg&hash=96939ffdedbb9915227750ccfa005ff0)
