Mr. Fixit
As I got the metal body that I built (T-Boy Topic Under Bodies), I needed to be able to rotate it 360 degrees to weld the underside, do the body work, priming, etc. Now that the body is completed, I have made a couple of simple adapters to mount the chassis from, which simplifies final welding, grinding and painting. The rotissorie is made up from two Harbour Freight engine stands which I cut the heads off of and welded a square pipe to which gives the height adjustability by various holes drilled in the tube. The square tube slides into the stands vertical tube and uses the brace bolt to adjust the centerline height of the spindle. What goes on the rotissorie is limited only by your imigination. This has proven to be a very useful tool for under $300 If anyone needs other info or photos, let me know..
View attachment: T-Boy 2010 0420 001 (Small).jpg
View attachment: T-Boy 2010 0420 002 (Small).jpg
