Johnny
What does is look like if you run the support rod over the front header tube, to the base of where the radiator will be, after you move the radiator back a few inches?
You going to make the rods yourself?
We make a few up here. We use 1/4 stainless rod with stainless 1/4 female heims. Run a die on the ends of the rod an screw on the heims.
This is pretty close to where radiator should be
