crank case venting
dustytrails
I want to put these on my 350 but as you can see there is no way to vent the crankcase,no holes in valve cover.I have a old school intake with a fill tube /breather but without a draft tube there is no way for the engine to breath ,how can i hide a pcv set up some where besides in the valve covers
I saw a guy on the HAMB, drilled a hole between the carb and distributor put it there with a valve cover grommet.
Hey Dusty, just read up on the valve covers you questioned about. They supposibly have the PCV and oil fill intergrated into them
LumenAl said:
Man those are cool! What is the history behind them, I don't think I've ever seen them before but I like them!
I know I'd seen them before and just found them again. They're in the speedway catalog.
