chopper tom
I have just been working too hard on it lattetly [ i seem to for get it's suppose to be a fun hobby ,i always work too hard on my projects and get burned out on them ]
I thought i had it fixed when last time i drove it ,it drove great[except for the carb,its junk] And i was way excited. butttttt,,,,,
when i went to drive it yesterday ,i found that the front drivers tire only had about 10psi in it and i know it must have been that way when i last drove it[i have had a slow leak on my big fancy ''junky''valvestems that i payed like 5 buckes for ,to heck with that ,i'm going back to my cheep rubber ones soon as i can,should had known better?]
So when i checked and corrected my tires pressures , i took it out for a spin and ''wowy o' wow'' its doing it again .but i found that the cotter pins [inthe 50 chevy ty rod ends was not there[i forgot them ]and was backed off alot!:surprised: So 'bingo'! i thought that had to be it,so i fixed it at break neck speed and hurryed out to try er out ,but to my dismay it had no change to the bounce.
I came home and looked in to my papaw's old Motor manual,from 1932 to 52.and it says to set the tow at 1/8 and the caster at +1/2 [wierd ,iknow but i'll try it !]
So thats were i am at ,on my next day off i'll try the caster and see what happens?
Thank all you guys for the support and info ,sure has helped!!!!
Nope ,RPM i still havent had time to check my drive shaft ,i just cant seem to get the stuff done that i want to do in a day off work,it would be nice to be in my 20's again i could have built two of these by now?!
