I had sorta the same problem. When I built mine using the CCR 15 body it is alot skinnyer than a regular 23 body and the radius rods were right under the body. I had some slight cracks right after just a few miles. So I added a 1" spacer between the leaf spring and rear spring mount on the frame. That did not get it up high enough and I did not want to add more spacer and longer bolts. So I cut the body some. It is not really noticable from the side too much.
If you added a spacer it would get your frame and body up higher by lowering the rearend.
http://i940.photobuc...http://i940.photobucket.com/albums/ad249/blownt/Problem1.jpg
http://i940.photobuc...http://i940.photobucket.com/albums/ad249/blownt/Problem06.jpg
How is your body mounted?
Lee,
its mounted to the frame with 4 bolts.
