Driveline question
schoon1547
Not sure if I'm in the right place but here goes I'm building a T and have a 95 mustang Donner car first I would like to use the rear ( disk brakes 8.8) and the front spindles and brakes. I don't see a problem with the rear but if I buy a tube axle front is there one out there that I can use the mustang spindles and brake rotters with? Thanks
Hi and welcome
We have a number of sponsors that will give the the facts on your question. Check back and I am sure there will be an answer that suits your needs
Gerry
I guess I should have said that I know the spindles wont work but I didnt know if there were any out there that the hubs and caliper bracket would fit. Thanks
Hey, welcome aboard! Theres alot of talent here with whatever tech stuff you may want or need!
OK, that outta the way, you can make most anything work. Just depends on your fab skills, machining abilities and/or bravery! Some of our members drive some really scarey stuff! Hahaha!
I'd call Pete & Jakes, or Competition Engineering......those two, possibly Speedway. Now, I know where you can get one made at, but it won't be cheap!
