Dyna Beads
coachfhs
My bucket is a little different that most...as you can see...spokes on the front...19inch motorcycle tires. Heres the question...what about these Dyna Beads to add to the tires for balancing instead of wheel weights. The way they weighted my wheels was to wrap a sort of wire around the spokes...i dont think you could even put weights on them because of the way it is made. Do these beads work.
Coach
I think stick-on weights will work with your front wheels.
If you cannot use the beads, there are other similar products that will work. And some folks even use anti-freeze.
I cannot off the top of my head remember the product I used with my mud tires, but it was a ceramic sand that worked really well. Similar to dyna-beads but in a sand format. That will allow you to put it in through the tube air inlet.
