EFI Bonus
Gerry
After the info on initial fire up and problem with running lean (Header wrecking). I thought you guys might be interested in this
Its a mixture control for WOT and idle. So if its running to hot I can adjust the mixture to richen it up.
Cool Eh
Gerry
Playing the Devils advocate. Are you gonna check the accuracy of the control unit? Is the control unit basically a pair of rheostats or is there more? This is a stand alone unit, no oxy sensor? What about cruise mode? Curious.
John
P.S. I see that WOT is set @ 11.
John
This feeds in to the ECU via a 16 pin plug, so I am presuming its taking an analogue signal, converting it to a digital one for the ECU to change the map. Yep I do have an 0[sup]2[/sup] sensor.
To quote the immortal words of Spinal Tap
Yeh but mine goes to 11
so why dont you make 10 louder... but mine goes to 11.
Gerry
