you can buy a fan wiring kit from jegs with the temp sender relay and wiring for abot 30 bucks. you will have to have a relay or it will feed back to the ignition and it will not die untill the fan stops spinningAny advice on doing this as far as wiring goes.Is there a simple way to make a thermostat so its not running constantly.
Please do post pics,This always helps everybody.Lets see your set-up Rooster...Thanx for all the info guys..Cool :2 if you want a pic of the relay location and the bracket let me know I will post one or two
