My thoughts exactly, a nice 5 blade non- flex fan is my plan. I'm in S.W. Fl, I know what you mean. Everyone has good points, it's what best fits your build !I'm running a stock fan with no shroud. I live in Central Florida with very high temps in summer along with a LOT of slow moving traffic. Even with all of this, I've never overheated. I just do not personally like the look or sound of an electric fan on an open air engine.
In mine, there is only room for a 12" mechanical fan. I plan to run it, but unsure if it will be enough to keep the bbc cool. It has a thick core radiator. I prefer mechanical fans, had too many electric fan failures over the years, but will run one if the small diameter fan won't keep up. I will add that the newer fans seem fairly reliable, as I don't often hear of them failing nowadays... Of course, the failure usually stems from faulty electronic components such as relays or thermostats. My other concern is there are under drive pulleys on it too, I will likely replace them and install a hi flow water pump. One thing I have learned over time is that a properly sized and functioning thermostat makes a big difference in maintaining temperature.My thoughts exactly, a nice 5 blade non- flex fan is my plan. I'm in S.W. Fl, I know what you mean. Everyone has good points, it's what best fits your build !
I would think 30 amps would be sufficient, but check the fan specs. As for placement, most electrics mount very close to the radiator, and come in push and pull orientation, so you can place them on either side of the radiator, many just use plastic wire tie type fasteners that fasten the fan directly to it. I don't like those myself, I prefer a shroud, with the fan mounted to it, but they do work. For a mechanical fan, as long as it won't contact anything, it's ok. The closer, the better, within reason. You have to keep in mind that they flex.Any idea of the amp draw on the electric fans? Also on the mechanical how close to the radiator?
You may need to use a diode too. I have had electric fans prevent the car from shutting off, bucause the fan acts as a generator when the power is cut and it can feed back through the system... A diode is an electric check valve, and only allows power to flow in one direction.If money is a issue, you can go to the boneyard an pull one off a mitsubishi/nissan/toyota, some of these have nice sized radiators, and attachment is easy. These usually are setup for 25 to 30 amps., and will flow all the air you will ever need, some even have variable speeds (As Per RR!)....instead of just on and off....but you usually have to run the correct temp sending unit for them....
I have found the VW Beetles fans to be excellent, if you can get them reasonable.
In this area, the skies the limit! Choose wisely and smart....And ALWAYS RUN A RELAY!
I hear ya, and agree, but I had one that would hold the relay in and prevent the ignition from shutting off. Until I figured out the issue, I had to plan to shut it off when the fan was shut off, lol... That was when I was young and knew everything...then I learned what a diode actually did. I always use relays and like them because you can tap the ignition feed on the high side of the ballast or resistor wire and the draw is low enough, it doesn't affect anything. Some relays come with a diode in them, especially if they are designed to control motors. I was always frugal (cheap) and used salvage stuff, so buying a relay was a rare event....it is likely I had a general purpose relay. Anyone else find it ironic that the older you get and the more you learn, the more you learn you have a lot to learn?Yep, your right, it can, thats why I run a isolated relay. Once the power is killed to the relay (wired into the ignition switch circuit, ie, turning the motor off), it releases, and the motor stops. Good call....
http://i759.photobucket.com/albums/xx240/bowtiet/352_zpsqa7grq2c.jpgWhether or not to use an elec. or mech. fan may be decided by if you can make an effective size mech. fan fit...on mine w/the engine as high as it is , I wouldn't be able to use anything bigger than about 12" & still clear the upper rad. hose but a 16" elec fits just fine..mine's been trouble free for 14 yrs. & 40K miles.
http://i759.photobucket.com/albums/xx240/bowtiet/352_zpsqa7grq2c.jpgMy problem too. 16" worked fine for meWhether or not to use an elec. or mech. fan may be decided by if you can make an effective size mech. fan fit...on mine w/the engine as high as it is , I wouldn't be able to use anything bigger than about 12" & still clear the upper rad. hose but a 16" elec fits just fine..mine's been trouble free for 14 yrs. & 40K miles.
