Mr. Fixit
The other day when I was about 2 blocks from returning home from a quick ride, I smelled coolant, looked at the temp gauge and it was above 240, then I was suddenly wearing some on my face. I pulled into the driveway and immediately noticed that the lower radiator hose had blown off of its neck. I let everything cool down, put the hose securly back into place and properly re-filled the system with coolant and distilled water.
Since then, each time I warm up the engine from cold, the temp goes up one time to about 225 and hovers there for a minute or so, then quickly drops to 190 (operating temp) when the thermostat opens. It will not go up again above normal unless I wait until the next day and repeat the process. I checked the t-stat and it seems to be operating when I put it in very hot water. Any suggestions?
Thanks,
Thanks,
