Hi guys, quick update, still recouping from my double knee replacements, possibly another month or two before the garage will see me.  I've be getting together lots of bits for my project (C-cab based on Dan Woods Ice Truck) I just picked up repro brass headlights made by a guy over here (Australia) they are just awesome, check out his web site Lights, Lamps and Lanterns   I know there were no headlights on the Ice Truck, I'm not building a duplicate just using some of the design features.
I also brought 2in. stainless tubing for the exhaust, I want the exhaust to look the same as the Ice Trucks, I need to make something to quieten the engine noise, I was thinking on getting 8, 3/4in by 12in long s/steel tubeing drilling them with holes then 24, 2in. diameter s/steel discs, also drilled with 3/4in. centre hole and 1/4in. holes around that, I will weld a disc both ends of the 3/4 tubing and one in the middle, this unit will then slide into the end of the 2in. exhaust, between the discs I could put s/steel drill shavings or something similar. WILL THIS WORK?
