Gerry
Hi
First time the Fad has seen tarmac, but its on the A frame.
With a one off set up like this T has I had no idea what to expect so a slow start around the block. Front end straight and true, rides the bumps like a T everything seems to work. rear springs are TOO heavy and will need replacing with lighter ones. Need to work on the front dampers as they are not 100 percent yet, but all in all better than I thought.
The only problem is the rear spoked wheels are running out of true. Not sure if this is because they have sat for 18 years as when they were done they were true. Now its a case of tyres off and back to the spoked wheel specialist. Could have done without this as the tyres are a pain to get off and on. They will be OK to use for the show. Its only a 40 mile trip.
Cant tell you it was a buzz as my mind was all over everything looking for problems. Enjoyed it ? kinda
Gerry
Gerry
