deckofficer
Banned
This was brought up in another forum but was someone else's thread so I'll move it here because it is electric. Some of you guys are running Odyssey batteries and have commented that you were amazed of the cranking amps of a 15 lb AGM battery. This hot rod scooter will outrun my Vette up to 40 MPH. The range is only 6 miles but a big golf cart charger will fill the drained batteries in about 25 minutes. For a race on Route 66 in Arizona, I was competing against gas scooters and it was for 50 miles. This scooter pulled a 490 lb battery trailer that gave it a range of 65 miles. I copied and pasted from the other thread some of the advantages of these type of batteries over regular automotive starting batteries...........
Odyssey AGM batteries have a self discharge of less than 1/10 of a regular battery, can be charged at more than 20 times the rate and has a 5 times longer service life. Plus when it gets old, it won't leave you high and dry because at the end of service life is still able to crank the amps, just not as long. This is a cranking battery that can be deep cycled like a deepcycle RV/marine battery. No corrision and mounting in any position is also a good feature. As I have been trained by the regulars on this forum, I will post the pictures, just took awhile to find them on the hard drive, then reduce in size to fit here.
Bob
Bob
