It's a lot more accessible than reaching for the dash. I don't want much on the dash other than the gauges, indicator lights, and the headlight switch. All of the other controls are going to be on the column, and gearshift so they are at fingers reach, no reaching or stretching. Because of where the shifter is and how I built the riser, there is a spot that lends itself well to the cigarette lighter and any other accessory switches, or whatever I may later add that is easy to reach and it will not be prone to interference with legs, etc. I am still debating weather or not to add a radio. Initially not, but I may incorporate provisions for a later upgrade. The seat riser will be the likely spot. It will be less than advantageous to see the selection though. Maybe I will just install an amp and speakers because I normally listen to my iPod anyways. Running out of space in a hurry.I was debating what to put in my seat riser, maybe even my ignition switch. I don't know how functional that will be.
I haven't actually paid any attention to the differences in the bodies because I just bought this car because of the components that are dated to my hey day.... It's a older molded body and has created a lot of work for me in my attempt to make it more to my taste. I was set to scrap it in favor of a stretched body, but after much debate, decided that I might as well build a new car if I stretched it because nothing was going to work without major redesign. Buying a new standard body would have likely not been much less work to adapt to my chassis, etc, so I just went with it. Comes a point where you either go with what you have or jump ship. I have it, so here we go... I didn't set out to buy or build a bucket. I actually have several other steel projects, but I happened across this and made a impulse sort of buy... I had recently sold a couple toys, so whatever. I was actually seriously considering a willy's coupe, still like them. I bet adding that door outline detail was a chore! I could pull it off, but building my dash was no fun. I thought I had it figured out, but the sub strait that I used to mold the basic shape didn't remain rigid enough and I ended up shaping and sculpting.... A tedious, repetitive task. What type hinges did you go with? I decided on the cast steel generic model A type. They are definitely overkill for the light doors. I have seen several variations using hardware store type, etc... But I was afraid they would look out of place and chose automotive style. Pretty pricey for no more than they need to be.As for the door outlines. I had to move my right side lines back 1" and then remake them with Duraglass. they had no room for the windshield posts to fit. A lot of bodies in the early days were like this. I now have 5/8" between the w/s posts and the front of the door outline. A lot of work. BUT now instead of a 17" door like Ford had I have a 16" door .
I made my concealed hinges , pretty much ripped off CCR design....used GM repl. bronze bushings , repaired a original 27 T style latch...whatever you decide to do , think ahead...I put T-nuts in the wood framing before glassed in the wood.... used wood/glass backed up by steel in the jambs for the striker & hinges.....If you have a facebook account & want pics , I can do that....PM if you wish .. dave
Dave, thanks! I have no idea what I done wrong, but I thought I had replied to you earlier. Anyway, that's a good idea about the t nuts, I hadn't thought of using them. I did consider the latch and strike. I plan on routing them in after the oak has been attached and finished perfectly flat inside before cutting the door out, then glass everything. Im stuck on the hinges... I can make the ones I have work, but I really don't want to cut such a deep pocket for them. Still under debate, lol.I made my concealed hinges , pretty much ripped off CCR design....used GM repl. bronze bushings , repaired a original 27 T style latch...whatever you decide to do , think ahead...I put T-nuts in the wood framing before glassed in the wood.... used wood/glass backed up by steel in the jambs for the striker & hinges.....If you have a facebook account & want pics , I can do that....PM if you wish ..
Those are cool, do you know anyone who has used them for such? I am wondering about the door swing, since it's not a plumb jamb, how it would swing. The ones I've seen use different length hinges to rectify it.This is what I was planning on using
SOSS® Invisible Hinges - Lee Valley Tools
I like their design. I found some reproduction model t hinges at Macs antique auto parts that are one piece and has the design that allows for the strange opening geometry, basically one hinge is longer than the other, sort of A shaped, so the door opens level. I am thinking about trying them out. I also like them because they are one piece, and the mounting is over a larger area, so it should be stronger...? I think that if both hinges are the same length, the door will fall shut, because the body is angled in at the bottom. The bottom hinge needs to be longer to compensate if you want the door to open normally and not fall shut. I don't know how much it would matter in reality because the door isn't too heavy, but it wouldn't stay open. At least that's my thought. I am trying to visualize it.... I may have it wrong, it may be the inverse, lol...Not sure ,, I just saw them online and thought they would be perfect.
I was just going to buy them and make them work.
