maxwedge426
I am in the process of mocking up my first T Bucket. I purchased the front axle from Ron Pope and the steering arms from Speedway. I have made the frame from lumber cut to match the size of the tubing that I will be using. My first question is, do most builders use a round front cross member so that the tie rod has more room to move up and down? I mocked it up with a square tube, but it looks like the axle will have to move farther out in front to have tie rod clearance. My spring perch is tangent with the top of the crossmember.
My second question is regarding the Ackerman Triangle. I have mocked everything up as close as possible, but it looks like the 3rd point of the triangle will be about 10-15 ft behind the car. How big a deal is that?
Thanks in advance
Thanks in advance
