Gas tank volume calculation
Track T-4
A while back someone posted the formula to convert the volume of a gas tank from cubic inches to gallons but I haven't been able to find it. Would appreciate if you could post it again.
My tank is a PITA - it doesn't have a sender, the curved neck doesn't allow using a stick, and it sometimes overflows when too full (all over the paint) - so I'm trying to figure out how to get around these issues until a fix can be installed.
Thanks.
Thanks.
The length x width x height will give you the cubic inches and then divide by 231. As there are 231 cubic inches in a gallon.
and in case its of any use there are 16.4cc in 1 cu inch
Gerry
Thanks guys.
Ron.....I'll be ordering a new tank when I get around to pulling the body off the chassis.
