Just shot primer on the body and the swage lines are all over the place. Anyone know any tricks to even them out and make them the same all over. By the way its a glass body.
Gerry
If by "swage lines" you mean the door outlines and the roll at the top of the body, I would suggest that you make a template out of aluminum or steel in the shape you desire. Then apply some filler to those areas and while it is still "wet", drag the template over the area removing all filler that is not part of the feature line that you want. This will give you a nice crisp feature.
If the above is not what you are after, let me know otherwise and I'll try to help more.
Gerry,Jim
Yep thts exactly what i mean. I have no door outlines but the swage along the top of the body that runs down the scuttle and the two that go vertical on the back panel are all over the place. They are so bad Im almost thinking of killing them all... but that would take away one of the features of a T so Im stuck with getting them smooth, the same shape and thickness. Thought about a template just wondered if there was another way. Added to that the radius on the bulkhead is different side to side. Another step forward and 3 steps back. Huh
Gerry
Gerry,
Since you are already in primer, body plastic would not be a good option to correct the lines without removing the primer. Use a 2 part finishing putty (Evercoat makes a very good one). Guide coat your primer with a contrasting color of primer (just dust it over your base primer)block your lines back where they belong an fill where needed. This is where patience comes into play.......ruggs
Has to happen when you havnt picked up a spray gun for a couple of years
As long as you have used an epoxy type primer it is perfectly acceptable, and in many cases recommended, to use a filler on top of it. It is best to do it within the window of a couple of hours of shooting the primer. If you wait longer you must really scratch it up with some 80 grit though. This is accepted practice in many pro shops.Gerry,
Gerry, the procedures that I have talked about in the above posts are exactly what I have used. All my feature lines are very crisp and clean compared to most commercial bodies out there. Just take your time and with the build talents that you have shown so far you will have NO problem.
Gerry,These pics may help. Is there a problem with putting bondo over primer? I have done it for years with no problems to date?? Just thought I would ask.
[attachment=4180:bodywork-(22).jpg]Has to happen when you havnt picked up a spray gun for a couple of years
[attachment=4181:bodywork-(5).jpg] [attachment=4182:bodywork-(6).jpg]
Gerry,
The pictures show runs, sags or whatever anyone cares to call them. Guide coat the run and block it out. Let it cure for a day and reprime. Sorry to differ with anyone but,40 plus years as a professional body and paint person says use 2 part finishing putty after your in prime. If you are to the primer stage you shouldn't have any imperfections that should need body plastic. JMO take it as you will......ruggs
Ruggs.
Thanks.
I put it in primer as the state of the body/'paint' was so very bad. Had to DA the hell out of it to get a clean surface. I have done loads of paint jobs in the past including graphics, murals and candy. Never had a problem except in the early days with a clear coat from Glasurit.
Plan was to get a good working surface and cherry it from there. Once all the filling and primer works is finished then shoot in yellow. I am using cellulose cause I prefer to work with that.
Once the yellow has been used for a 'protection' coat I plan to seal it with 2 pack sealer and then shoot the final coat of HOC Candy red. Remember this is only a yellow protection coat and so I can see how the car stands in that color.
May be all wrong about this but as I mentioned never had a problem to date. The chassis will be grit blasted before the red is layed but you cant really do that to a glass body.. or can you.?
Thanks for all the help.
Gerry
Every inch by hand is the way to go, as that body is small anyway, compared to a regular full sized car :egypt: guide coat every primer coat so you can see just what you are doing and with that comes no OVER sanding... Did you ever give the Yellow a thought as to being your base coat for the Red Candy paint?? as every different colour base coat changes the final look of any Candy colour, some here use Silver, some use Gold, some White each with a totally different out come, test a few under colours to see which you like best... That body has a great look, wish mine was that low on the sides and up that high in the back.Hey Ruggs
Need your help and experience. Spent 2 days on the body so far and got the back panel straight along with the scuttle and sides
BUT these feature lines are driving me mad. I made a template and tried to run the filler in with it... no go. I tried to scrape the result with the template (3mm steel) and agin no go.
I am now down to just working every inch by hand.
[attachment=4219:bodywork1-(8).jpg] [attachment=4220:bodywork1-(10).jpg]
[attachment=4221:bodywork1-(12).jpg] [attachment=4222:bodywork1-(1).jpg]
Any ideas?????
I might have had to many brews so i dont know.What body is that?Hey Ruggs
Any ideas?????
Every inch by hand is the way to go, as that body is small anyway, compared to a regular full sized carguide coat every primer coat so you can see just what you are doing and with that comes no OVER sanding... Did you ever give the Yellow a thought as to being your base coat for the Red Candy paint?? as every different colour base coat changes the final look of any Candy colour, some here use Silver, some use Gold, some White each with a totally different out come, test a few under colours to see which you like best... That body has a great look, wish mine was that low on the sides and up that high in the back.
Gerry, If you can hold off until tomarrow night I will go to the shop and damage a body line.Then I get you some photos of how to fix it...........ruggsHey Ruggs
Any ideas?????
