TriodeLuvr
I seem to be working my way through my new/used bucket one broken part at a time. Coming up very soon, I need to replace the leaking rear axle seals. If I can ID the rear end, I'll be able to buy the seals before I pull the axles. I don't have a lot to go on, but I think this is a Mustang 8" and that it's '67-up (the vertical ribs on the carrier). Unfortunately, there's no ID tag. I've posted a few pics below.
Searching online, I don't see many 8" rear ends with a two-dimple case like this one. Most have one dimple and a drain plug. Based on that, my first question is whether anyone knows if this case design was restricted to only a few years, say '67-'70 or something like that. Second, is it possible to tell whether this is definitely a Mustang axle, or was this case design also used in other models?
Any help with this will sure be appreciated.
Jack
Jack
