Driver50x
I had planned on mounting a Mustang II floor shifter in this thing. After I realized how much precious floor space that was going to use up, I switched gears on that plan.
I built myself a custom shifter assembly. All of the commercially available shifters that I saw place the shifter near the rear of the transmission. I wanted it towards the front of the trans for two reasons - 1) it frees up some foot room on the floor, and 2) it mimics the look of an old top loader transmission.
I made the main frame out of 1/2 inch square tubing, and the shift lever out of 1/2 inch round stock, and a few other metal scraps laying around the shop. I welded a 3/8th inch bolt to the top of the shifter, and screwed on an old cut glass door knob that was resting in one of my junk drawers.
It might be a little hard to tell from the pictures, but the shift linkage goes from the drivers side of the shifter back to a bell crank, and then forward to the transmission.
On the passenger side of the shifter I built a reverse lock out mechanism. It consists of a “slider” assembly that has a hole in it for park, and a slot for drive and neutral. The spring loaded pin is actuated by a cable (a bicycle brake cable) which will run to a knob located on the seat riser. This will prevent the shifter from being accidentaly bumped into reverse. It will also act as a theft deterrent. It will be impossible to get the car out of park without knowing how and where the release knob is.
I spent a good amount of time fiddling around with this thing, getting it to clear everything and getting the geometry worked out. I went through a couple design changes.
The final design is not real pretty, but it will be covered up anyway, and it works great. This is more fun to me than ordering a part from a catalog.
