Mike
Now that Internet Explorer 9 has been officially released, there have been some compatibility issues with JavaScript and Invision Power Board. As it turns out, the JavaScript library used within IPB 3.1 was a point release behind the library IE 9 was designed to use.
I've been using IE9 since it's earliest Beta release last summer and have not encountered any JavaScript issues. Apparently someone has had an issue with it, so a patch file has been added to assure compatibility.
If you are using IE9 and are experiencing some issues, you will need to clear your browser's cache in order to allow this change to take effect.
