Well, the screws are history. Unbelieveable how tight the nuts are - impossible to remove. With two fans running (ceiling and table) and the tank filled completely with water there were plenty of sparks but no need to call 911. I was just able to squeeze the dremel in to get the screw heads ground off. No matter how you do it I'm not comfortable working around a gas tank with a flame or sparks. Now to unbolt and remove the body, solve the tank issue, new master cylinder, driveshaft hoop, wire turn signals and a few other things and hopefully back on the road soon. Thanks for all the thoughts and suggestions.
