I just bought a total performance project that has never been on the road. It was built, taken apart, painted and powder coated and looks pretty good (metalflake purple body) but I need to replace the motor. It has a junk 350 in it now and I have a new crate 350 to go in. I notice that the motor actually sits at an angle with the front of the motor higher than the back. I am pretty sure that the motor mounts were welded in by the builder rather than by TP as there are several different qualities of bead on different parts of the frame. Now, should the motor set parallel with the frame, parallel with the ground, or parallel with the body with someone sitting in the bucket. The motor mounts in there are welded so that the top of the plate is at the top of the frame on both sides and they angle down front to back. Is this the way they should be? I have a really old TP assembly manual but can't find what angle the motor mounts should sit at.
Thanks!
Thanks!
