Hi,
Plugging along on my first T build (rebuild)... am assembling Speedway's dropped tube axle kit. All is well until I get to mounting the front shocks. My brain says that the shock body should be on the bottom as does Speedways frame assembly pix in their catalog. Their assembly manual for their T kit however shows the shock body on the top. From an interference standpoint, there's a lot more room between the radius rods and shock if the body is up. Is the shock (PRO shocks) designed to be mounted in either direction or must it be mounted a certain way?
Thanks,
olguy
Thanks,
olguy
