Ive been upgrading a track-T I bought back in March. Its powered by a 2800 Pinto with an automatic transmission and we only drove it about 1/4 mile to the garage when it was delivered. I finally got it back together and started yesterday and was hoping to take a trial run but when I shut the engine off there was a puddle of trans fluid under the car. When the car is running tt leaks with a pretty quick drip at the front/bottom off the trans right behind the engine at the inspection cover. What might be causing this? Is there a seal in the front of the trans that might have gone bad? Or something else? It doesn't appear to be leaking from any visible fitting and doesnt appear to be overfilled.
Is it possible that circulation through the cooler is blocked? Would that cause it to push fluid out in this manner? No reason to think that is the problem, its just a thought.
Are there any automatic transmission experts out there? Im not real anxious to pull the trans but Im afraid thats where this is heading. Your input/experiences would be appreciated.
