s19243h
thanks for all your advice guys i ordered the crower cam will check all clearances  think ill break the cam in with the old intake and carb dont want to wast the cam with trying to get the motor to run  with the tunnel after cams broke in then ill put it on have another ? since im running progressive do i set idle and air mixture on both carbs or just my primary ( the back one) and keep the blades closed on the front one
