Need some help!!!!!
Did you make your wiring harness, or did you buy one ? That would give us some idea on where to start. Turn signals can be done different ways.
just a guess but i would check the hot wire going into you signal switch.
Darn, I didn't think of that one. Have to remember that one.
Tbucit said:
...some of the bulb sockets could let you put the 1157 bulb in backward, guess what we checked and changed them and all is fine...
Randall
That's nuts! a little QC from the MFG of the sockets and this would have never happened... however this is one of the reasons when it comes to lights, I always check sockets with a multimeter first to see if I'm getting power then, then work backwards from there.
Glad you found it!
