Here is a new front bat wing we designed, it is now available on our drop tube axles at no extra charge. The one lone hole out there all by itself is for a shock. In the row of 5 bolt holes the 2 outers are drilled 3/8" for the radius rod clevis to bolt to. The 3 center holes are 1/2" for the spring pivot to bolt into. These extra holes allow you to raise or lower the front of the car 2 1/2" just by simply moving the pivot stud.
The regular bat wing that we used for years will still be installed unless this one is requested at the time you order.
