I only have Trans. and rear end at this moment but I will be getting a t least a bare block shortly.Mike
First off WELCOME you have come to the right forum
Besides the body what other parts do you have
I started with the frame on my build
I was lucky enough to have all the parts needed for the build then I assembled the frame AND now I am dealing with the body
hope this helps
Ron at RPM is a great guy (He will even call you back if you don't leave a message)
He will advise you through this build and so will the guys on the forum
Frank
I'm in Estero, just south of Ft. Myers.Mike J, where in Florida are you located?
I also have the steel for the frame, but I'm going to mock up the chassis first out of wood that I already have made 2x3 for better accuracy. I'd rather make a mistake with wood first. lol.I only have Trans. and rear end at this moment but I will be getting a t least a bare block shortly.
I don't I have a problem getting advise from Ron or anywhere else on these forums by the looks of it so far, thanks. Mike J
I'm not channeling the body, as you called it I'm going to zee the frame 3" so iI don't loose interior space. Thank you, I will do it that way so i'll probably need a trans. tunnel before long. Mike JNow that you have the body, build the frame and mock up the engine and trans. Leave the eng and trans in the frame. Channel the body to fit, Now make a cardboard pattern to fit for the floor. The reason you left the eng and trans installed so the floor will fit around it all. Then install the floor once it all fits good. Then you can do the trans tunnel at the same time. If you have any questions, just give me a call. I REALLY don't mind one bit.
I am keeping all receipts and I will start getting serial #'s, just in case. I just mocked up the wood frame tonight and I will post pics when I figure out how to do it. I've seen a thread on how to post pics, now I'll have to actually read the whole thing...Welcome. You've gotten good advice so far and I won't add anything about your floor, but if your just starting you will want to save all the receipts for what you use to build the car even the steel you use for the frame. If you have any serial numbered items (block, trans, some rearends, etc), be sure to get a bill of sale on them. Some states want a paper trail for all traceable items.
I don't know how the registration process goes in Florida, but I had to have all those things when I titled mine in Louisiana. You might want to go by or call the DMV and get a heads up on the registration process for your state now. It would really suck to get it done and have problems on that end.
Good luck and have fun! BTW Post pics of the build progress. Everyone likes to see them.
Mike
By all means Wayne look me up, maybe by then it will be a roller. I mocked up the wood frame yesterday, Looks good . I'll try to do some pics today, but i don't know which forum to put them in. Do you? By the way do you know what IMHO and IMO are ? I'm new to some of the abbreviations. Mike J.
