I was about to hijack another post into a direction unintended by the original author. So I decided to start a new post here instead. Here's the relevant portion of the quote.
Joecool,
I'm interested in your use of quarter elliptic springs at both ends of the car because I'm considering doing something similar. These are not criticisms (as in, "Why didn't you do it the right way, like me?"), I'm just trying to learn, (as in, "I've never built anything. How does that work?").
Does the lower spring do a good job of holding the axle from moving from side to side - either from hard cornering or from little bumps as you're driving straight? How about on the rear? Did you find you needed a panhard bar on either end of the car? Why did you put the spring on the bottom instead of the top?
Could you have put two lighter springs at each end of the axle - one on top and one on the bottom?
Could you have eliminated the top mount altogether by mounting the spring solidly to the axle, exactly like you mounted it to the frame?
Inquiring minds want to know...
Here's the original post in context.
http://www.tbucketeers.com/forum/f7/setting-up-quarter-elliptical-springs-2198/
joecool said:I built a Modified type car with 1/4 elliptics and they worked out great.
But I used 57 Chevy springs and cut them in half,using the stiffer shorter front half for the front and the longer in the rear. I drilled holes in them and bolted them to a reinforced lower frame rail. I then put tabs on the axle ( not shackles) and used those as the method for raising and lowering the ride height to suit me.
By not using shackels I was able to use the spring as the bottom link in what is like a four bar ar four link. I then used a upper link to locate the top of the axle.
Joecool,
