No...No....NO
Track-T
Don't even park by this guy...
sweet!! he doesnt even know to use teflon tape in the joints or they could stick togather and youll never get them apart..galvanized to black iron, tisk tisk tisk,,,, lolololol
Oh you must be pointing out the plug wire close to the manifold.Lol That is what I call a widowmaker.
How about those homemade u-joints, the single set screw in each coupling allowing them to swivel. He did not even phase them correctly. This guy MUST have a death wish is all I can figure.
Its one thing to be a low buck builder but you just can't fix stupid!
I hear Banjo music when i look at that picture. Also look at the bolt that is holding the exh manafold on the far left . The 3/8 bolt was to long so a 1/2 nut and for safety reasons i am sure a lock washer was needed as well.
Plus He uses a combo brake valve, that just takes away pressure, does not add any... only cuts it down, the rear brakes need all they can get, I went that way once... :lol: hard to believe that spacer is not even spot welded, what was he thinkin??? hehe :(
I would never park next to a car that dirty, it might make mine look clean :lol:
Ted i dont think this guy took the science of brakes into consideration , I will bet their is a used car lot somewhere missing the brake system on what ever was left unlocked that night.
Well, just goes to show. You can make it fool proof, but not dam fool proof. Please don't tell me, it belongs to a T-Bucket.
:sad:
if you notice that the exhaust manifold is acting as a header... ummm.... what ever happened to headers?!?!?!?!?!
Track_T.... the question that has been missing here is who's car is this?!?!?!?!?!?! can you please clarify? Not that he would, but, I would hate to be talkin about Roosters car while he's reading my post here!!!!! eeeeerrrrrr.....Thanks!!!!!!! :D:D:D:D:D:D:D:D:D
And then there is the "R" word. Crap like this has got to STOP! When you see it, in a polite way, point out how it could hve been done the right way, As broke as I am. I would have either helped him get the right set up or pointed him in the right direction.
Don't worry,It is no one we know.
I pulled it from another site.
no u-joint required with all that slop between the D ends and the 3/4" couplings. Why didn't I ever think of that?
