KPoole9008
I have a GM crate engine with the numbers 1M09020H04 stamped on it. Does anyone know what it came out of? I know it's a 350 4 bolt main. Thanks
ttI also have a GM crate motor.
Did you get them numbers from the rear of the motor or the front?
The info on mine was not easy to find.
I found it with the numbers from the rear driver side, where the trans mounts to the block. I think it started with 140 or GM then the numbers
But is was a 350 4 bolt main, Stock, Made in Mexico. 1980 -1990
oh ya Casting number.
Well, as to what it came out of, the only sure answer is -- are you ready? A crate! Seriously, you'll probably need to check with a GM Performance Parts dealer. They can probably link the ID number to the specifications for that engine.
Bob
And a casting number like 3970010 isn't really telling you anything in particular, other than the fact the block is a large journal, 4.000" bore block.
Of course if you have one, you can always sell it as 'an extremely rare '68 or '69 327 block'. No, really, they only made them for just the two years... :thumb:
