tfeverfred
Okay, after my fun run today, I noticed I had oil leaking from the front of my intake AND oil blowing out of my dip stick tube and it blew all over my Miss behavin' decal!
! Well, I fixed the dip stick tube by making it seal better. It was a cheapo I got from the auto parts store. Now, the oil coming from the intake is probably just a sealing problem that will be addressed later on by just changing out the gasket set. It's not a major leak, but it is noticeable.
But is it possible that I have a problem that is causing a build up of pressure? Any thoughts?
Oh, I didn't have this problem before switching valve covers. One VC breather has a PVC in it. Maybe I don't need the PVC and should use the two plain breathers that came with the new covers or could the PVC breather be clogged? And changing back to my old valve covers is NOT an option!
