akitagandy
Alright guys I need a mig welder for sheet metal up to say 1/4" , I have a stick welder for heavy stuff but I will only have about $300 to spend so I am looking at Harbor Frieght What do you think?
For use with or without gas. Preset for gasless flux-core operation.
Welds material from 22 gauge to 1/4'' thick
Thermal overload protection with warning light
Adjustable wire feed control
Wheel kit for maximum portability
Comes with welding torch, 1.0 and 0.8 tips, grounding cord with clamp, brush/hammer, hand held welding mask, carrying handle and wheel kit; Input: 230V, 60 Hz, single phase; Welding current range: 35-140 amps (working), 160 amps maximum, Duty cycle: 100% @ 35 amps,18% @ 140 amps; Draws 25 amps @ 230V; Max. open circuit voltage: 20V; Weldable wires: 0.023 to 0.03 0 inch steel and stainless steel; 0.030 to 0.035 inch flux core and aluminum
Tool weight: 93.5 lbs.
![93793.gif](/proxy.php?image=http%3A%2F%2Fi551.photobucket.com%2Falbums%2Fii457%2Fakitagandy%2F93793.gif&hash=e4cdbe3dd607798bd0d3a39612b53ab9)
